Введение
Video tutorial - how to replace Laser Lens only:
Выберете то, что вам нужно
Видео обзор
Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
On some models, like the CECH-2501B, there are multiple ribbon cables that connect the Blu-ray drive to the motherboard. The ribbon cable with this particular retaining flap may be found underneath the Blu-ray drive itself. Reattaching that ribbon cable to its socket underneath can be very difficult, but not impossible. it just requires a skilled hand and plenty of patience to get it done.
Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
Remove the Blu-ray drive from the PS3.
my cd drive has 3 cables, two by the fan, one right under, i believe i damaged the one on the bottom because it is very difficult to put back in hence the repair. But the photos here dont show the 3 cables, not sure if you have one for this model?
I followed the steps and I successfully removed my disc drive the guide was helpful but I had issues and the ribbon cables on my replacement disc drive were too short after a soddering attempt failed I now need to rebut a disc drive can someone direct me to a proper replacement with the correct size I need it's a ps3 slim 120G please help
Completely different drive in my slim. 3 ribbon cables on the back that pull straight up out of their connectors. And one wide ribbon hidden underneath and almost impossible to get to. After disconnecting the 3 visible cables lift the back of the drive about 3/4" and use a plastic spudger to release the clip on the cable before lifting off the drive. Reinstalling is a nightmare. The cable has a black line to indicate how far to insert into the connector. Get it in there somehow then use the spudger to push the clip down. If it's not level release it and try again and again and again until you get it right. Sony must use some awfully small fingers when they build these ;-)
I had the same issue with the ribon feeding beneath the blu ray player. This video provided a much better solution. It requires dissassembling the blu ray: https://youtu.be/Upy2bTev3M0
My disk drive needs to be replaced. Your step by step is straight forward and are very helpful. At the end you mentioned “If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive”.
Which circuit board? Can your please add a picture of the circuit board you are referring to?
@hh168 There’s now a link in the text of that step, which will take you to a video with detailed instructions for swapping the board.
First I replaced the drive and it would load a disc and see that it was either a game and which game or a BluRay or DVD and which, but I got error codes when trying to play them.
The codes seemed to be tamper coding, and swapping the board seemed to be a good idea.
It went smoothly, but now discs will not feed into the drive.
Please help.
20 участников успешно повторили данное руководство.
5 Комментариев
yo vendo amigo = ivaramso@gmail.com para ventas
What does the white and black cable?
Robert Brown - Ответить
They are the wifi and Bluetooth antenna connections
Jason Dufford -
