Введение
Use this guide to replace your PlayStation 3 Slim's CR 2032 coin-cell PRAM battery.
Запчасти
Никакие детали не требуются.
  1. Turn the PS3 over and lay it on its backside.
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. Lift the top cover from its rear edge and rotate it toward the front of the PS3. Lift the top cover off the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply. Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  8. Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  9. Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  10. Lift the power supply upward from its left edge as viewed from the front of the PS3.
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  11. Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture. Remove the power supply from the PS3, minding any cables that may get caught.
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  12. If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive. If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  13. Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  14. Pull the Blu-ray ribbon cable straight up and out of its socket.
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  15. Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  16. Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  17. Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing. Remove the Blu-ray drive from the PS3.
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
  18. While holding the plastic retainer down against the board, use the tip of a spudger to pry the PRAM battery out of its housing.
    • While holding the plastic retainer down against the board, use the tip of a spudger to pry the PRAM battery out of its housing.
    • Failure to hold the plastic retainer down during the prying process may result in it tearing off the motherboard.
Заключение
12 участников успешно повторили данное руководство.
Один комментарий
ATTENTION: This guide is not valid for PS3 slim CECH-3004B!
from the number 11 you notice that your ps3 is different.
The CECH-3004B version does not give direct access to the 2032 battery.
You must also disassemble the motherboard from the grid (and all the pieces that obstruct this operation)
It is possible but it is more difficult
Marco Bedini - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 4
За 7 дней: 33
За 30 дней: 209
За всё время: 31,548
