Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The guide will show users how to remove the laser lens of the PlayStation 3 Super Slim. By showing the removal of the correct screws and cables, the guide will be able to give users the ability to remove their optical drive from its enclosure. After removing the optical drive, The user will open up the optical drive to be able to remove the laser lens. This allows for the replacement of a component of the PlayStation 3 Super Slim that reads the Blu-Ray discs.
  1. Remove the side HDD bay cover by sliding the panel towards the back of the device. The bay cover is found on the right side of the device.
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
    Just wanted to add: the HDD bay cover isn't on the right all the time, it varies with each unit. The side without the rubber PS logo is the bay cover.
    Yash - Ответить
  2. Remove all three black 9.8mm long screws with a T-8 security screwdriver. Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. Pull on the tab to remove the HDD. The HDD should be removed and stored carefully to prevent damage to data.
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. On the bottom of the device, pry out the three rubber feet covers with the metal spudger. Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure. Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
  6. Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver. Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver. Remove the top black plastic shell.
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. Move the optical drive to the side to reveal one of the silver 8.8mm long screws. Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver. Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
    be careful, the fiber-optic cables come out easily and are a pain to put back in
    tucker hartman - Ответить
  9. Remove the cable from the plug and remove the wires from the two plastic hooks. When removing the cable from the plug, pull on the plastic male connecter, not on the wires. Remove the power supply unit.
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
    The left side of the PSU sits on two long metal prongs so you may need to pull a little to get it lose but you should be able to pull the whole unit in an upward motion
    Matthew Symmons - Ответить
  10. Remove the front white flex-ribbon cable by pulling upward from its base. Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable. Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
    • Remove the front white flex-ribbon cable by pulling upward from its base.
    • Remove the black and blue flex-ribbon cable behind it by pulling upward on the black tab, then pulling out the cable.
  11. Rotate the device 180 degrees. Remove the back white flex-ribbon cable by pulling upward from its base. Remove the optical drive.
    • Rotate the device 180 degrees.
    • Remove the back white flex-ribbon cable by pulling upward from its base.
    • Remove the optical drive.
  12. Lift up the free end of the laser lens to separate the two layers. On the bottom of the laser lens, flip up the black plastic latch to remove the flex ribbon cable. On the bottom of the laser lens, flip up the black plastic latch to remove the flex ribbon cable.
    • Lift up the free end of the laser lens to separate the two layers.
    • On the bottom of the laser lens, flip up the black plastic latch to remove the flex ribbon cable.
  13. Remove the 4 rubber bushings. Remove the metal faceplate from the laser lens. When inserting your new lens, attach the top metal casing to the replacement laser lens.
    • Remove the 4 rubber bushings.
    • Remove the metal faceplate from the laser lens.
    • When inserting your new lens, attach the top metal casing to the replacement laser lens.
Заключение
5 участников успешно повторили данное руководство.
Joseph O'Connor
Участник с: 14.04.2016
1 687 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 34-13, Maness Spring 2016 Участник Cal Poly, Team 34-13, Maness Spring 2016
CPSU-MANESS-S16S34G13
4 членов
Автор 17 руководств
Комментариев: 3
so i did follow this to a tee and not only does the laser not want to work but it keeps makeing this buzzing sound whenever the disk tray is closed
is there something i might be doing wrong
dave raschke - Ответить
Very Good but please show us how to remove lens only
wtersad - Ответить
like the video,
Where is the parts purchased from?
Thanks Joe
jdpassanisi - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 25
За последние 30 дней: 153
За всё время: 5,374
