PlayStation 3 Super Slim Power Supply Unit Replacement
Выберете то, что вам нужно
  1. PlayStation 3 Super Slim Power Supply Unit Replacement, Power Supply Unit: шаг 1, изображение 1 из 2 PlayStation 3 Super Slim Power Supply Unit Replacement, Power Supply Unit: шаг 1, изображение 2 из 2
    • Remove the side HDD bay cover by sliding the panel towards the back of the device.
    • The bay cover is found on the right side of the device.
    Just wanted to add: the HDD bay cover isn't on the right all the time, it varies with each unit. The side without the rubber PS logo is the bay cover.
    Yash - Ответить
    I just wanted to add that the above is not correct either
    My PS3 Super Slim Mdel No. CECH-4004A has the removable PS logo rubber seal on the left side while the HDD is housed behind the right side (with no rubber PS logo seal)
    Eoin - Ответить
    My p3 just went off it goes on but then it just shut down
    Chadley Abrahams - Ответить
  2. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 2, изображение 1 из 2 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 2, изображение 2 из 2
    • Remove all three black 9.8mm long screws with a T-8 security screwdriver.
    • Remove the blue 7.9mm long screw with a Phillips #1 screwdriver.
  3. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 3, изображение 1 из 2 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 3, изображение 2 из 2
    • Pull on the tab to remove the HDD.
    • The HDD should be removed and stored carefully to prevent damage to data.
  4. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 4, изображение 1 из 2 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 4, изображение 2 из 2
    • On the bottom of the device, pry out the three rubber feet covers with the metal spudger.
    • Remove the four black 36.3mm long screws underneath with a Phillips #1 screwdriver.
    • One screw is located underneath the warranty sticker. This sticker can either be peeled off or punctured through with a screwdriver.
  5. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 5, изображение 1 из 2 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 5, изображение 2 из 2
    • On the top of the device, unlatch the hook on the furthest right beneath the front panel, lift the panel slightly and apply pressure.
    • Unlatch the second right-side hook by sliding a plastic opening tool in the marked area.
    • Slide the panel to the left to unlatch the rest of the hooks.
    • This is probably the most difficult part of the procedure. If you cannot unlatch the hook on the front panel, you can attempt to pry all the hooks off. However, do this at your own risk, as these hooks break easily.
    Getting these on is harder than getting them off.
    Jake - Ответить
  6. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 6, изображение 1 из 1
    • Remove the back panel by pressing down the tab on the right side of the device, and sliding the panel to the left.
  7. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 7, изображение 1 из 3 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 7, изображение 2 из 3 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 7, изображение 3 из 3
    • Remove the five silver 20.8mm long screws with a Phillips #1 screwdriver.
    • Remove the two black 9.9mm long screws in the disc reader with a T-8 security screwdriver.
    • Remove the top black plastic shell.
  8. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 8, изображение 1 из 3 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 8, изображение 2 из 3 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 8, изображение 3 из 3
    • Move the optical drive to the side to reveal one of the silver 8.8mm long screws.
    • Remove the two silver 8.8mm long screws on either side with a Phillips #1 screwdriver.
    be careful, the fiber-optic cables come out easily and are a pain to put back in
    tucker hartman - Ответить
  9. PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 9, изображение 1 из 3 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 9, изображение 2 из 3 PlayStation 3 Super Slim Power Supply Unit Replacement: шаг 9, изображение 3 из 3
    • Remove the cable from the plug and remove the wires from the two plastic hooks.
    • When removing the cable from the plug, pull on the plastic male connecter, not on the wires.
    • Remove the power supply unit.
    The left side of the PSU sits on two long metal prongs so you may need to pull a little to get it lose but you should be able to pull the whole unit in an upward motion
    Matthew Symmons - Ответить
Заключение
Install the replacement power supply unit. To reassemble your device, follow these instructions in reverse order.
22 участников успешно повторили данное руководство.
Joseph O'Connor
Участник с: 04/14/16
2 383 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 34-13, Maness Spring 2016 Участник Cal Poly, Team 34-13, Maness Spring 2016
CPSU-MANESS-S16S34G13
4 членов
Автор 21 руководств
8 Комментариев
Perfect how to guide. Fixed my PS3 easily. Thanks
Andrew Roscoe - Ответить
Great guide. However, still no power on PS3. Any suggestions as to what else may be the problem?
Peter Maher - Ответить
Peter Maher, I am in the same boat. I have no idea what the problem is. Red light in standby, but as soon as I try to power on, nothing. Same as before I did this power supply replacement. Obviously, something else is the problem. Anyone who has some insight into this please help!
James Neely - Ответить
Did you guys get word on the red light with no power on fix mine has the same issue.
Benjamin P Patterson -
i have the same problem as Peter Maher, the red light is in standby neither turning green on pressing nor it sounds beep on long press. dont know whats wrong. anyone has any solution to this?
Thiemwang Kitnya - Ответить
my ps3 red light is not working at all could this be the problem I mean the power supply
Mohammed - Ответить
thanks for guide - had a blown power unit and this was a useful guide to getting at it so it could be replaced. I couldn’t see a guide for taking the power unit apart so with nothing to lose I opened that up to see what was going on, and could see the charred remains of what I guess was a capacitor.  New power unit in there now and working great. thanks
Phil March - Ответить
Fantastic guide, I used it today to check if my PS3 brought from the US could be plugged in a 220 socket (as I had read on this site). I can confirm this is the case, as the power supply is actually the 100-240V one (part # N12-160P1A). Thanks for this great piece of information!
Vincent - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 79
За последние 30 дней: 348
За всё время: 29,017
