Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
Remove the following seven screws:
Six 52 mm Phillips screws
One 30 mm Phillips screw
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
Remove the top cover.
There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
47 участников успешно повторили данное руководство.
