Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This step-by-step procedure will allow the reader to get to and replace the optical drive responsible for reading the disc. Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty.
Выберете то, что вам нужно
Remove three 9.7 mm Torx security screws.
Remove two 41 mm Phillips screws and brackets.
Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
Remove the optical drive four wire plug from the motherboard by pulling straight out.
Remove the four 9mm Torx T9 screw attached to the wifi antenna and optical drive.
Remove the 5mm Phillips head #1 screw.
The optical drive assembly can now be lifted straight up and removed from the system. Do not discard the daughter board.
181 участников успешно повторили данное руководство.
71 Комментариев
This was a great help after my 2 yr old put a coin in my PS4. However when following the steps backwards I got to step 7 which says 'Remove the 5 wire plug attached from the power supply to the motherboard' & couldn't see how to reattach it. I then noticed it looks like I've pulled the whole plastic white casing/plug holder (within the orange rectangle) off the mobo rather than just the plug from the casing. Although the pic looks like the plastic casing does come off the mobo as it's at an angle (maybe why I pulled the whole thing out or maybe I did it right).
I'm thinking I've made a mistake is because now I cant see anywhere that I can 'plug' the 5 L shaped wires on the bottom of the plastic casing back onto the mobo. Plus where they used to be attached there's now 5 tiny silver rectangles on the mobo (2 opposite 3), so I guess these 5 wires were some how adhered to those mobo rectangles by a conductive adhesive of some sort.
Any suggestion for the best repair method would be appreciated.
Thanks
If you've pulled the female end from the motherboard the it need to be resoldered to the board, most likely gonna need to pull the motherboard. It's a very simple connector, sounds as if you yanked the whole thing off.
lynx2069 -
Is anyone there who try to change the optical drive without change the Motherboard in the same time ? And does it run ?
Thanks for your help.
How about a guide for replacing just the laser unit instead of the whole drive?
I changed the drive with its motherboard, when I want to update the system, an error message appears:
CE-42116-8 .
