Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Use this guide to remove and replace your PS4 Slim's motherboard.
  1. Locate the plastic warranty sticker next to the three ports on the side of the console. Remove the warranty sticker by peeling it off with any kind of spudger. Removing the warranty sticker will NOT cause your warranty to be null and void.
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
    Remove the screw directly to the left of that one in the picture as well. Should be silver.
    Elizabeth Johnson - Ответить
  2. Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion. Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
    Are you SURE that it’s counter-clockwise?
    The Stuff - Ответить
  3. Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you. Pry up on the two corners that are facing you with your fingers. This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
    It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
    Vidal Santos - Ответить
  4. Place the Playstation 4 Slim right side up,  with the PS logo on top and the side with the words "SONY" and "PS4" facing you. Pry up on the two corners that are facing you with your fingers. This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion. Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion. Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. Remove the four 16mm Philips screws holding the power supply in place.
    • Remove the four 16mm Philips screws holding the power supply in place.
    Es gibt diese Schrauben bei meiner Ps4 Cuh 2116A nicht und ich bekomme das Teil so nicht raus. Kann mir jmd helfen?
    Julian S. - Ответить
  7. Remove the metal sheet from the top of  the power supply by grabbing and lifting up with your hands. Remove the metal sheet from the top of  the power supply by grabbing and lifting up with your hands.
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
    Is this metal sheet required for the unit to power on?
    AlexT - Ответить
  8. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  9. Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel. Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
    The Hondo - Ответить
  10. Flip the Playstation 4 Slim onto its back. Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    Forgot to mention to remove the hard drive.
  11. Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two. Lift the power supply up and onto its back on the metal sheet using your hands. Lift the power supply up and onto its back on the metal sheet using your hands.
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  12. Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out. Remove the power supply completely by grabbing and lifting up with your hands. Remove the power supply completely by grabbing and lifting up with your hands.
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
    Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
    Chicky Boy3 - Ответить
  13. Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion. Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
  14. Locate the two wires connected to the bottom of the motherboard. Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
    • Locate the two wires connected to the bottom of the motherboard.
    • Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
  15. Flip the device to the backside. Unscrew and remove 14x 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Flip the device to the backside.
    • Unscrew and remove 14x 4.0mm black screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 8x 6.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove 4x 3.0mm silver screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    - There are 14x 4.0mm black screws, but the step only shows 13 of them circled in red. One of the 11 orange circles (near front of unit) is actually the 14th black screw. Photo: http://i.imgur.com/7G64egd.png
    - As for the 6.0mm silver screws, there are only 8x of those. The two silver screws behind the IO ports on the back are 3.0mm fine-threaded screws. Photo: http://i.imgur.com/cQD6KQu.png
    - Source: Have a PS4 Slim (CUH-2015A) right in front of me, doing this exact job. Hope this helps someone else down the road.
    lane anderson - Ответить
  16. Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion. Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
    These are 3.0mm screws, not 5.0mm. This step could probably be condensed into the previous step.
  17. Locate the white wire connected to the corner of the top of the motherboard. Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches. Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
    • Locate the white wire connected to the corner of the top of the motherboard.
    • Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches.
    • Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
  18. Remove the connections by pulling out on the blue tabs with your fingers. Flip up the black clip on the largest tab with your finger before removing it. Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
    • Remove the connections by pulling out on the blue tabs with your fingers.
    • Flip up the black clip on the largest tab with your finger before removing it.
    • Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
  19. Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself. You may need to wiggle the plate a bit to get it loose before you lift it out.
    • Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself.
    • You may need to wiggle the plate a bit to get it loose before you lift it out.
    • Do not lose any of the black pads attached to the motherboard while performing this step.
    This step would benefit from showing a picture of the black pads in question. Pic: http://i.imgur.com/zQnehtA.png
  20. Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion. Remove the small metal plate by grabbing it with your fingers and lifting up. Remove the small metal plate by grabbing it with your fingers and lifting up.
    • Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion.
    • Remove the small metal plate by grabbing it with your fingers and lifting up.
    Why is one silver and one black? I keep thinking they are different and try to keep track of where they go.
    Reed Deemer - Ответить
  21. Remove this wire connection by firmly grasping it with tweezers and pulling out. This might require a bit of force to disconnect, but be sure not to break any of the wires. This might require a bit of force to disconnect, but be sure not to break any of the wires.
    • Remove this wire connection by firmly grasping it with tweezers and pulling out.
    • This might require a bit of force to disconnect, but be sure not to break any of the wires.
  22. Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up. You may need to wiggle the board a bit to get it loose before you remove it.
    • Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up.
    • You may need to wiggle the board a bit to get it loose before you remove it.
Заключение
25 участников успешно повторили данное руководство.
Harry Koos
Участник с: 24.01.2018
2 074 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S19-G4, Livingston Winter 2018 Участник Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 членов
Автор 21 руководств
Комментариев: 7
Hi Harry
I think this guide is fantastic. My PS4 slim is not coming on. It’s not the HDMI display port or anything of the sort. It powers on, you hear the beep and the blue power light stays on. That’s all. Nothing after this… no signal to the TV, cannot reinitialise, nothing. I’ve checked online to see if I can diagnose it. Based on the few signs I’ve seen I think the board is gone. So am looking to replace that hence I came across your guide. Is there a way you know to be certain my board is faulty. Thanks
Jx Corp - Ответить
I have a PS4 slim issue…. when connected to power it doesn't show it’s on and no light displays….. I would say the board is faulty and how do I work on such problem.
michael quartey - Ответить
do you need to change the optical drive as well?
Hafiz Adam - Ответить
my ps4 slim power supply ok no power motherboard
Naeem Tyagi - Ответить
Very good repair guide, but it’s incomplete. The first step is remove the HDD (hard disk drive).
Yeong - Ответить
We don't need thermal paste, or to replace the optical drive?
Thembiswa Dlamini - Ответить
My PS4 Slim Output has a-lot of static interference and idk y
skydimondlox - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 66
За последние 7 дней: 449
За последние 30 дней: 2,123
За всё время: 25,554
