Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to remove and replace your PS4 Slim's motherboard.
Выберете то, что вам нужно
Locate the plastic warranty sticker next to the three ports on the side of the console.
Remove the warranty sticker by peeling it off with any kind of spudger.
Unscrew and remove the now exposed 5.0mm screw using a T8 security Torx screwdriver with a counter-clockwise motion.
Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
Pry up on the two corners that are facing you with your fingers.
Remove the bottom cover by sliding it towards the back corners and lifting up.
Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
Remove the top cover by sliding it towards the back corners and lifting up.
Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
Flip the Playstation 4 Slim onto its back.
Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
Lift the power supply up and onto its back on the metal sheet using your hands.
Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
Remove the power supply completely by grabbing and lifting up with your hands.
Unscrew and remove the 31.0mm safety screw using a T8 screwdriver with a counter-clockwise motion.
Locate the two wires connected to the bottom of the motherboard.
Remove the wires by firmly grasping the metal connections with your fingers or tweezers and pulling up until they disconnect.
Flip the device to the backside.
Unscrew and remove 14 black screws (4.0mm) using a Phillips #1 screwdriver with a counter-clockwise motion.
Unscrew and remove eight silver screws (6.0mm) using a Phillips #1 screwdriver with a counter-clockwise motion.
Unscrew and remove four silver screws (3.0mm) using a Phillips #1 screwdriver with a counter-clockwise motion.
Unscrew and remove the two 5.0mm screws on the side of the console using a Phillips #1 screwdriver with a counter-clockwise motion.
Locate the white wire connected to the corner of the top of the motherboard.
Disconnect the wire by firmly grasping the metal connection with your fingers or tweezers and pulling up until it detaches.
Unthread the wire from the tape and move it off to the side using tweezers or your fingers.
Remove the connections by pulling out on the blue tabs with your fingers.
Flip up the black clip on the largest tab with your finger before removing it.
Remove this wire connection by firmly gripping the wire with your fingers and pulling it out.
Remove the metal plate by grabbing two sides of the plate and lifting up and away from yourself.
Unscrew and remove the two 10.0mm screws (one silver and one black) using a Phillips #1 screwdriver with a counter-clockwise motion.
Remove the small metal plate by grabbing it with your fingers and lifting up.
Remove this wire connection by firmly grasping it with tweezers and pulling out.
Remove the motherboard by grabbing the edge of the board with one or two hands and pulling away and up.
61 участников успешно повторили данное руководство.
10 Комментариев
Hi Harry
I think this guide is fantastic. My PS4 slim is not coming on. It’s not the HDMI display port or anything of the sort. It powers on, you hear the beep and the blue power light stays on. That’s all. Nothing after this… no signal to the TV, cannot reinitialise, nothing. I’ve checked online to see if I can diagnose it. Based on the few signs I’ve seen I think the board is gone. So am looking to replace that hence I came across your guide. Is there a way you know to be certain my board is faulty. Thanks
I have a PS4 slim issue…. when connected to power it doesn't show it’s on and no light displays….. I would say the board is faulty and how do I work on such problem.
do you need to change the optical drive as well?
my ps4 slim power supply ok no power motherboard
