PlayStation 4 Slim Power Supply Replacement
Выберете то, что вам нужно
  1. PlayStation 4 Slim Power Supply Replacement, Bottom Cover: шаг 1, изображение 1 из 3 PlayStation 4 Slim Power Supply Replacement, Bottom Cover: шаг 1, изображение 2 из 3 PlayStation 4 Slim Power Supply Replacement, Bottom Cover: шаг 1, изображение 3 из 3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Power Supply Replacement: шаг 2, изображение 1 из 2 PlayStation 4 Slim Power Supply Replacement: шаг 2, изображение 2 из 2
    • Unscrew and remove the 5.0mm screw that was behind the sticker using a T8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Power Supply Replacement: шаг 3, изображение 1 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 3, изображение 2 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 3, изображение 3 из 3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
  4. PlayStation 4 Slim Power Supply Replacement, Power Supply: шаг 4, изображение 1 из 3 PlayStation 4 Slim Power Supply Replacement, Power Supply: шаг 4, изображение 2 из 3 PlayStation 4 Slim Power Supply Replacement, Power Supply: шаг 4, изображение 3 из 3
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
  5. PlayStation 4 Slim Power Supply Replacement: шаг 5, изображение 1 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 5, изображение 2 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 5, изображение 3 из 3
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  6. PlayStation 4 Slim Power Supply Replacement: шаг 6, изображение 1 из 1
    • Remove the four 16mm Philips screws holding the power supply in place.
  7. PlayStation 4 Slim Power Supply Replacement: шаг 7, изображение 1 из 2 PlayStation 4 Slim Power Supply Replacement: шаг 7, изображение 2 из 2
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
  8. PlayStation 4 Slim Power Supply Replacement: шаг 8, изображение 1 из 2 PlayStation 4 Slim Power Supply Replacement: шаг 8, изображение 2 из 2
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
  9. PlayStation 4 Slim Power Supply Replacement: шаг 9, изображение 1 из 2 PlayStation 4 Slim Power Supply Replacement: шаг 9, изображение 2 из 2
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
  10. PlayStation 4 Slim Power Supply Replacement: шаг 10, изображение 1 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 10, изображение 2 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 10, изображение 3 из 3
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Power Supply Replacement: шаг 11, изображение 1 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 11, изображение 2 из 3 PlayStation 4 Slim Power Supply Replacement: шаг 11, изображение 3 из 3
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
Заключение
64 участников успешно повторили данное руководство.
Hernan Rodriguez
Участник с: 01/24/18
3 296 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S19-G4, Livingston Winter 2018 Участник Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 членов
Автор 35 руководств
4 Комментариев
Can the N15-160P1A power supply work on a PS4 system that originally came with N17-160P1A?
derasky4u - Ответить
This was awesome. Thanks for the assist
Christopher Gorgon - Ответить
I need help figuring out what I did to my ps4 and what needs replacement I had the new nba 2k 22 in the disc drive and the game was partly finished downloading so as it was doing that I brought shinobi striker which I previously had to use someone’s account to play it so the game popped up as light so I deleted it the first time and redownloaded it and it still said lite so then I deleted again but this time I double tapped the PlayStation button and it went to Home Screen slowed down then froze so I unplugged it plugged it back up and it wouldn’t turn on
Deontay - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 42
За последние 7 дней: 278
За последние 30 дней: 1,317
За всё время: 78,365
