PlayStation Optical Drive Replacement
Выберете то, что вам нужно
  1. PlayStation Optical Drive Replacement, Open the Console: шаг 1, изображение 1 из 1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    The SCPH-9001 model does not have the Parallel Port panel to remove.
    Aislinn - Ответить
  2. PlayStation Optical Drive Replacement: шаг 2, изображение 1 из 2 PlayStation Optical Drive Replacement: шаг 2, изображение 2 из 2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Optical Drive Replacement, Remove the Optical Drive: шаг 3, изображение 1 из 2 PlayStation Optical Drive Replacement, Remove the Optical Drive: шаг 3, изображение 2 из 2
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
    I broke the optical drive power cable’s socket off from the motherboard! How to put it back on?
    B H - Ответить
  4. PlayStation Optical Drive Replacement: шаг 4, изображение 1 из 3 PlayStation Optical Drive Replacement: шаг 4, изображение 2 из 3 PlayStation Optical Drive Replacement: шаг 4, изображение 3 из 3
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
    While I was pulling this cable, the whole connector came off the motherboard (the white part that's supposed do stay on the motherboard)... How can I fix it?
    Zvezdan Disic - Ответить
    Same exact problem with pulling the entire connector off the motherboard. What do i do?
    Aaron Loyd - Ответить
    Yes, could try clean and re-solder, and do a proper re-work job.
    leafybye - Ответить
    help! i just had the same problem! someone was able to solve it ???
    Jack - Ответить
  5. PlayStation Optical Drive Replacement: шаг 5, изображение 1 из 2 PlayStation Optical Drive Replacement: шаг 5, изображение 2 из 2
    • Lift the optical drive straight up to remove it.
Заключение
46 участников успешно повторили данное руководство.
Craig Lloyd
Участник с: 02/10/16
35 418 Репутация
Автор 82 руководств
4 Комментариев
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
leafybye - Ответить
What about model SCPH-5501?
janis Nasuta - Ответить
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
The invader 2 - Ответить
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
John Reeves - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 110
За последние 30 дней: 466
За всё время: 62,386
