Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This will guide you through the replacement of your Power Supply.
Выберете то, что вам нужно
Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
24 участников успешно повторили данное руководство.
4 Комментариев
im done removing the power supply so whats next???btw i accidentally plugged my ps1 110v to 220v how to fix that issue???
Before anything unplug your PlayStation and try the power button couple a times to turn on the PlayStation.
Just check the fuse with a multimeter. It is a cylindrical tube with metal on it’s two corners. The easy way is to check continuity with a mutimeter which is a symbol with a speaker on it. Touch red and black probes and you will hear a beep. Connect the two ends of the fuse and if it beeps then fuse is ok. You can even check it while fuse is on the board. If ok and PlayStation is not working then there is a problem somewhere else on the power board, mostly…
Good Luck!!
gUru0026 -
