Введение
However, the Sony engineers also included a thermal pad to aide heat transfer in their design. These thermal pads can be worn out with excessive use, or severe overheating events. After this, it is best to replace the pads to keep the device performing optimally.
Выберете то, что вам нужно
Use the plastic spudger to pry up the bottom piece of the case to release the clips.
Remove the heat shield using the plastic opening tool.
Slide the tool around the edges until the shield is free.
Wipe down the area where the old thermal pads were located with rubbing alcohol.
3 участников успешно повторили данное руководство.
