Введение
A damaged or broken cooling fan can make your system overheat so it is important to replace it if that happens in order to prevent any further damage to the system.
Выберете то, что вам нужно
On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
Unscrew the 6mm screw with a PH #000 screwdriver.
Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
With the plastic opening tool, carefully pry the console shell panel free and lift it away.
Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
Carefully lift the fan and its wiring from the device.
8 участников успешно повторили данное руководство.
4 Комментариев
Where do I get a replacement fan tho?
5V is what i have read
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
