Введение
This guide will show you how to remove and replace the lenses of the PlayStation VR Headset. This can be a challenging task, but with a little patience it can be done.
Выберете то, что вам нужно
Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
Use the plastic opening tool to pry the top white plastic panel free from the headset.
Flip the headset over.
Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
Carefully pull the end of the white ribbon connector from its slot.
Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
Remove the yellow LED ribbons and black plastic connecting piece from the headset.
Using the tweezers, unplug the three (one black bundled, two multi colored bundled) connector cables from their ports along the circuit board.
Unscrew the two 7 mm screws near the lenses with a PH #000 screwdriver.
Flip the headset back over.
With your fingers, carefully pry the top black plastic panel free.
Unscrew one silver 4 mm screw from the white plastic band connecting the rest of the headset.
One 4 mm screw with a PH #000 screwdriver.
Using a finger, press the black plastic tab up to loosen the white connector piece.
Slide the white plastic connector piece back and lift up to remove it.
Unscrew the five silver 6 mm screws from the circuit board.
Five 6 mm scews with a PH #000 screwdriver.
Using your fingers, lift up on the sides of the black plastic piece holding the circuit board in place.
There are small plastic tabs on the side that latch the piece in place that need to be lifted in order to remove it.
Using a hairdryer (or heatlamp), warm the area around the lenses. This will help loosen them for removal.
Using a glass cloth (or any cloth with soft fibers), carefully press on the lenses until they pop out of place.
26 участников успешно повторили данное руководство.
24 Комментариев
Wow..this looks a lot harder than it should be. I bought my PSVR used and the lenses are kinda scuffed up, like the previous owner cleaned them with something not perfectly soft. I was hoping they’d come out easily from the front, but I guess that’s not the case. Thanks for the immensely difficult guide!
Yep, where to buy the lenses?
Where can i buy new lenses for the PSVR?
