Введение
This guide takes you through the process of installing the 3G antenna cable on the PlayStation Vita. This is the black antenna cable on the left of the wireless.
Выберете то, что вам нужно
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
Continue working your way around the device gently prying it open.
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
Using the pointy end of a spudger, gently pry the 3G antenna cable off the right button board.
Deroute the 3G antenna cable out of the casing and remove it.
2 участников успешно повторили данное руководство.
Один комментарий
I need mine fixed because it has came out but it isn’t a wire it is like a orange thin thing and it won’t clip back in
