Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide takes you through the process of installing the Wireless Card on the PlayStation Vita.
Выберете то, что вам нужно
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
Continue working your way around the device gently prying it open.
Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
Hook the spudger beneath the tab on the wireless card casing and release the tab.
Peel up and remove the wireless card casing.
Remove the two 4.4mm Phillips #00 screws on the wireless card.
Pull out the wireless card.
3 участников успешно повторили данное руководство.
4 Комментариев
i am takig my vita apart (moving all boards/chips into new oled lcd screen/ front part) and am having trouble taking the wifi chip out in order to take out the right button board, the screw closest to the right button board is i think stripped, is there an easy and non harming way to the motherboard of taking that screw out?
Rubber band .
Duck -
umm, just took mine apart and there isnt a card nor a card holder.... what?
Then you have the Wi-Fi only version. Only the model with the 3G modem actually has that slot. This part is the 3G modem module. The actual Wi-Fi chip is on the mainboard not as a separate module.
