Выберете то, что вам нужно
Now flip the system back over to its top. 'Be sure not to drop the top when you pick it up.
Pick up on the top case after you have flipped it over. This will have a little resistance but this should not break anything if you have all of the five screws out of the under case.
Then undo the piece holding in the ribbon cable. When you do this grab the side of the black piece holding it in place and pick it up slowly
