Введение
The whole Playstation 3 is cooled by a single fan on its bottom side. In this guide, we will remove that fan so that it may be cleaned or replaced.
  1. Remove the rubber screw cover near the hard drive cover with a spudger. Remove the rubber screw cover near the hard drive cover with a spudger.
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Remove the screw holding the top cover in place with a Torx T10 screwdriver.
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Slide the top cover down about half an inch. Lift the cover off of the PS3.
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Remove the seven screws in the top cover with a Phillips #2 screwdriver. One of the screws is shorter than the others. The short screw is marked in yellow.
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. You can now lift off the top cover. You can now lift off the top cover. You can now lift off the top cover.
    • You can now lift off the top cover.
  6. Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back. Push down the tab on the connector to disconnect the wires.
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Remove the power supply by lifting it straight up. Remove the power supply by lifting it straight up.
    • Remove the power supply by lifting it straight up.
  9. Unplug the optical drive power cable. Detach the ribbon cable that connects the optical drive to the motherboard.
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Remove three screws (Phillips #2) from the wireless board and antenna. Detach the ribbon cable that connects the wireless board to the motherboard.
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Remove the hard drive door with a spudger. Lift the metal enclosure out of the plastic bottom case. Lift the metal enclosure out of the plastic bottom case.
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Remove the three screws (Phillips #2).
    • Remove the three screws (Phillips #2).
    • Disconnect the fan's power cable.
    • Lift the fan straight up and out.
Заключение
iDeleted
Участник с: 07.07.2010
2 101 Репутация
Автор 39 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 2,780
