Введение
This guide provides the steps to separate the Playstation 3 motherboard from its metal enclosure. This allows the motherboard to be replaced if necessary.
Выберете то, что вам нужно
Remove the rubber screw cover near the hard drive cover with a spudger.
Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
Remove the two screws on the front of the power supply.
Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
Unplug the optical drive power cable.
Detach the ribbon cable that connects the optical drive to the motherboard.
Set the optical drive aside.
Remove three screws (Phillips #2) from the wireless board and antenna.
Detach the ribbon cable that connects the wireless board to the motherboard.
Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
Remove the hard drive door with a spudger.
Lift the metal enclosure out of the plastic bottom case.
Remove four black screws (Phillips #2) from the top plate of the motherboard enclosure.
The two, small plates held down by the screws should become loose. Remove these plates.
Lift the motherboard to separate it from the rest of the enclosure.
Detach the two ribbon cables from the motherboard.
3 участников успешно повторили данное руководство.
