Введение
This guide explains how to take apart the Sony PlayStation 3 optical drive. These steps are useful for repairing or replacing the optical drive.
Выберете то, что вам нужно
Remove the rubber screw cover near the hard drive cover with a spudger.
Tilt the front of the optical drive enslosure upwards.
Lift the black ribbon cable latch on the back side with your finger or a spudger.
Disconnect the ribbon cable.
Flip over the optical drive enclosure. There are four ribbon cables connected to the circuit board. Using a spudger or your finger, lift each ribbon cable latch and disconnect each ribbon cable.
Remove the three screws on the board with a Phillips #00 screwdriver.
Remove the two silver screws on the bottom of the case. These screws are different from the ones on the board and should be kept separate.
Using your thumbs, carefully bend out the sides of the metal enclosure.
Lift the plastic enclosure out of the metal enclosure.
Flip over the enclosure so that the circuit board is on the bottom and the optical sensor is on top.
Remove the screw on the optical sensor using a Phillips #00 screwdriver.
Remove the tape on the red and black wires that connect to the optical sensor. With the wires still attached, take the sensor off the ensclosure.
Remove the four black screws on the edges of the enclosure using a Phillips #00 screwdriver.
Flip over the enclosure again.
Remove the rest of the screws in the corners of the circuit board.
Flip over the enclosure. Remove the black, plastic cover so that the drive and its enclosure match the first picture.
Using a spudger, lift the brown latch and disconnect the small ribbon cable.
Remove the four fat screws in the corners of the optical drive.
Using a spudger, lift the black latch and disconnect the larger ribbon cable.
2 участников успешно повторили данное руководство.
Один комментарий
When reassembling it there is a key part that needs to be exactly inline. see this video for help: http://www.youtube.com/watch?v=hzHPRGHFj...
