Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the rubber screw cover near the hard drive cover with a spudger.
Remove the screw holding the top cover in place with a Torx T10 screwdriver.
Slide the top cover down about half an inch.
Lift the cover off of the PS3.
Remove the seven screws in the top cover with a Phillips #2 screwdriver.
Lift the optical drive enclosure and disconnect the grey wires.
Tilt the front of the optical drive enslosure upwards.
Lift the black ribbon cable latch on the back side with your finger or a spudger.
Disconnect the ribbon cable.
Flip over the optical drive enclosure. There are four ribbon cables connected to the circuit board. Using a spudger or your finger, lift each ribbon cable latch and disconnect each ribbon cable.
Remove the three screws on the board with a Phillips #00 screwdriver.
Remove the two silver screws on the bottom of the case. These screws are different from the ones on the board and should be kept separate.
Using your thumbs, carefully bend out the sides of the metal enclosure.
Lift the plastic enclosure out of the metal enclosure.
Flip over the enclosure so that the circuit board is on the bottom and the optical sensor is on top.
Remove the screw on the optical sensor using a Phillips #00 screwdriver.
Remove the tape on the red and black wires that connect to the optical sensor. With the wires still attached, take the sensor off the ensclosure.
Remove the four black screws on the edges of the enclosure using a Phillips #00 screwdriver.
Flip over the enclosure again.
Remove the rest of the screws in the corners of the circuit board.
Lift the circuit board off the enclosure.
Remove the metal plate.
Flip over the enclosure. Remove the black, plastic cover so that the drive and its enclosure match the first picture.
Using a spudger, lift the brown latch and disconnect the small ribbon cable.
Remove the four fat screws in the corners of the optical drive.
Using a spudger, lift the black latch and disconnect the larger ribbon cable.
2 участников успешно повторили данное руководство.
Один комментарий
When reassembling it there is a key part that needs to be exactly inline. see this video for help: http://www.youtube.com/watch?v=hzHPRGHFj...
