Fix Your Stuff
Right to Repair
Parts & Tools
Введение
This is the main cover to the PS3. You must take this off to access everything but the hard drive.
Запчасти
Детали не указаны.
  1. Remove the rubber screw cover near the hard drive cover with a spudger. Remove the rubber screw cover near the hard drive cover with a spudger.
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Remove the screw holding the top cover in place with a Torx T10 screwdriver.
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Slide the top cover down about half an inch. Lift the cover off of the PS3.
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Remove the seven screws in the top cover with a Phillips #2 screwdriver. One of the screws is shorter than the others. The short screw is marked in yellow.
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. You can now lift off the top cover. You can now lift off the top cover. You can now lift off the top cover.
    • You can now lift off the top cover.
Заключение
2 участников успешно повторили данное руководство.
iDeleted
Участник с: 07.07.2010
2 101 Репутация
Автор 39 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 2,078
