Введение
This guide will show you how to replace the “Open” button on the PlayStation Classic.
Выберете то, что вам нужно
Remove the back plate from the rest of the console using your hands or the Jimmy tool.
Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
Remove the motherboard using the previous guide and isolate the top shell of the casing.
Use the Spudger to apply pressure inwards on the three plastic clips highlighted in the red circles.
After all three clips are pushed in, apply pressure on the cylindrical piece circled in red.
Push softly on the button till a small gap is created on the other side.
Use the black spudger to softly pry out the open button from the top of the casing.
Once enough of a gap has been created, use your fingers to grab and slowly remove the open piece.
