Введение
This guide explains how to replace a pneumatic door closer. This item can be used on a daily basis and is subject to stop working over time due to excessive use.
Выберете то, что вам нужно
Remove the screws from the inner brackets that connect to the door closer using a screwdriver.
Remove the screws from the outer bracket that connect to the door closer using a screwdriver.
Install the inner bracket that attaches to the door closer by screwing the inner part into the wall using a screwdriver.
Plug the smallest included screw into the inner bracket to attach the door closer.
Close the door.
Install the outer bracket that attaches to the door closer by screwing it into the door using a screwdriver.
Attach the door closer into the installed outer bracket by plugging the larger included screw into the inner part.
Make sure the door closes and opens properly.
Adjust the hydraulics by loosening or tightening the screw on the top of the hydraulic axle to have optimal performance.
