Введение
Motherboards can be damaged when there is injury to the device or even during a power surge. When either occurs, this often results in a computer that will not power on or respond. This guide shows how to replace a defective motherboard in a Poin2 Chromebook 11.
Выберете то, что вам нужно
Power down the Poin2 Chrombook 11 and disconnect the power adapter.
Close the Chromebook and position it with the base facing up.
Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
Insert a 1cm-wide plastic opening tool between the base and top frame.
Pry (up and down) around the entire border of the Chromebook to separate.
Use your hands to gently lift the base away from the frame.
Unplug the white 8-wire battery connector using a spudger to push the two L-shaped clips out of the socket.
Use a spudger (or fingertips) to flip up the plastic clamps that hold down the two ribbon cables connected to the motherboard.
Pull the cables from their sockets.
Disconnect the speaker and charging port cables by pulling the connectors out of their sockets.
Use a #000 Phillips screwdriver and remove the twelve 4mm screws that hold the motherboard.
Use a plastic opening tool and pry around the edges of the motherboard to release.
