Polaroid A10 Motherboard Replacement
Выберете то, что вам нужно
  1. Polaroid A10 Motherboard Replacement, Back Cover: шаг 1, изображение 1 из 3 Polaroid A10 Motherboard Replacement, Back Cover: шаг 1, изображение 2 из 3 Polaroid A10 Motherboard Replacement, Back Cover: шаг 1, изображение 3 из 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Motherboard Replacement, Motherboard: шаг 2, изображение 1 из 3 Polaroid A10 Motherboard Replacement, Motherboard: шаг 2, изображение 2 из 3 Polaroid A10 Motherboard Replacement, Motherboard: шаг 2, изображение 3 из 3
    • Take off yellow tapes that are surrounding the motherboard.
    • Use the plastic opening tools to disconnect the three ribbon cables: battery, screen, and volume/power buttons.
  3. Polaroid A10 Motherboard Replacement: шаг 3, изображение 1 из 3 Polaroid A10 Motherboard Replacement: шаг 3, изображение 2 из 3 Polaroid A10 Motherboard Replacement: шаг 3, изображение 3 из 3
    • Using the Phillips #000 screwdriver, remove the four 5 mm screws located in the picture by rotating the screw counter-clockwise.
  4. Polaroid A10 Motherboard Replacement: шаг 4, изображение 1 из 2 Polaroid A10 Motherboard Replacement: шаг 4, изображение 2 из 2
    • Use the soldering tool to unsolder the two bigger metals from the wires of the battery.
    • Use the same soldering tool to unsolder the four smaller metals from the wires of the speakers.
    • Use the same soldering tool to unsolder the ground wire.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Motherboard Replacement: шаг 5, изображение 1 из 3 Polaroid A10 Motherboard Replacement: шаг 5, изображение 2 из 3 Polaroid A10 Motherboard Replacement: шаг 5, изображение 3 из 3
    • Gently lift the motherboard up and out of the device.
Заключение
Еще один человек закончил это руководство.
Tracie
Участник с: 01/22/15
119 Репутация
1 руководство автора
Команда
UW Tacoma, Team 3-3, Rose Winter 2015 Участник UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 591
