Polaroid A10 Speakers Replacement
Выберете то, что вам нужно
  1. Polaroid A10 Speakers Replacement, Back Cover: шаг 1, изображение 1 из 3 Polaroid A10 Speakers Replacement, Back Cover: шаг 1, изображение 2 из 3 Polaroid A10 Speakers Replacement, Back Cover: шаг 1, изображение 3 из 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
  2. Polaroid A10 Speakers Replacement, Speakers: шаг 2, изображение 1 из 1
    • The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
  3. Polaroid A10 Speakers Replacement: шаг 3, изображение 1 из 3 Polaroid A10 Speakers Replacement: шаг 3, изображение 2 из 3 Polaroid A10 Speakers Replacement: шаг 3, изображение 3 из 3
    • Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
    • Carefully remove the speakers from original position without pulling out the wires.
  4. Polaroid A10 Speakers Replacement: шаг 4, изображение 1 из 1
    • Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
    • The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
    • Removal and installation of wires requires soldering. Here's a helpful link to assist you with great soldering techniques.
  5. Polaroid A10 Speakers Replacement: шаг 5, изображение 1 из 1
    • Gently lift the speakers up and out of the device.
Заключение
Koby
Участник с: 01/22/15
104 Репутация
1 руководство автора
Команда
UW Tacoma, Team 3-3, Rose Winter 2015 Участник UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 членов
Автор 12 руководств
3 Комментариев
This is not what I meant I wanted to know what to do if the wires came out of the
amirahoresanwo - Ответить
If the wires and out of the
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 242
