Введение
Use this guide to replace the speakers on your Polaroid A10.
Выберете то, что вам нужно
Begin by having the side with volume and power button face up towards you.
Insert a plastic opening tool between the display and the back cover.
Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
The speakers are located on the bottom of the device, below the battery and adjacent to the motherboard.
Using the Phillips #000 screwdriver, remove the two 7 mm screws located in the picture by rotating the screw counter-clockwise.
Carefully remove the speakers from original position without pulling out the wires.
Using the soldering tool, remove the two small black wires and two small red wires from the motherboard.
The wire connections are located on the motherboard next to the corner of the battery closest to the motherboard.
3 Комментарии к руководству
This is not what I meant I wanted to know what to do if the wires came out of the
If the wires and out of the
Speaker right
