Запчасти
Детали не указаны.
  1. Polaroid LCD-0700P Front Panel Buttons Replacement, Case: step 1, image 1 of 2 Polaroid LCD-0700P Front Panel Buttons Replacement, Case: step 1, image 2 of 2
    • Turn the entire device over, so that the underside of the device is facing upward.
    • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
  2. Polaroid LCD-0700P Front Panel Buttons Replacement: step 2, image 1 of 2 Polaroid LCD-0700P Front Panel Buttons Replacement: step 2, image 2 of 2
    • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
    • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
    • Be careful when separating the front and back covers, as the two are held together by a thin wire.
    • Separate the halves of the case.
  3. Polaroid LCD-0700P Front Panel Buttons Replacement: step 3, image 1 of 1
    • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
    • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
  4. Polaroid LCD-0700P Front Panel Buttons Replacement, Input/Output Board: step 4, image 1 of 3 Polaroid LCD-0700P Front Panel Buttons Replacement, Input/Output Board: step 4, image 2 of 3 Polaroid LCD-0700P Front Panel Buttons Replacement, Input/Output Board: step 4, image 3 of 3
    • Use two blue plastic opening tools to remove the three wire connectors on the side of the input/output board.
    • Use a Philips #0 screwdriver to remove the five screws on the board.
    • One of the screws is hidden below the black tape, so gently pull the tape to the side to gain access to it. Be sure to replace the tape when reinstalling the board.
    • Lift board from case.
  5. Polaroid LCD-0700P Front Panel Buttons Replacement, Logic Board: step 5, image 1 of 3 Polaroid LCD-0700P Front Panel Buttons Replacement, Logic Board: step 5, image 2 of 3 Polaroid LCD-0700P Front Panel Buttons Replacement, Logic Board: step 5, image 3 of 3
    • Remove the five different connections to this board. Two from the speakers, two from input/output board and the orange ribbon cable.
    • Remove connections from input/output board and speaker with the plastic opening tool.
    • Remove the orange ribbon cable using the plastic opening tool to release the two brown retention tabs.
  6. Polaroid LCD-0700P Front Panel Buttons Replacement: step 6, image 1 of 3 Polaroid LCD-0700P Front Panel Buttons Replacement: step 6, image 2 of 3 Polaroid LCD-0700P Front Panel Buttons Replacement: step 6, image 3 of 3
    • Remove the seven 5mm screws using the Phillips #0 screwdriver.
    • Detach the wire mesh tape connection the logic board to the LCD screen with the sharp end of the spudger.
    • Remove the logic board with your hands.
  7. Polaroid LCD-0700P Front Panel Buttons Replacement, Front Panel Buttons: step 7, image 1 of 1
    • Peel back the tape holding the button clusters down.
  8. Polaroid LCD-0700P Front Panel Buttons Replacement: step 8, image 1 of 1
    • Slide Button clusters off of positioning posts.
Заключение
Mario T
Участник с: 09.01.2012
457 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 8-14, Maness Winter 2012 Участник Cal Poly, Team 8-14, Maness Winter 2012
CPSU-MANESS-W12S8G14
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,211
