Введение
If you need to replace the film door latch, use this guide to access the inside of the camera. You may need to replace the latch if your camera will not close.
Выберете то, что вам нужно
Unscrew the four 5mm screws on the base of the camera using a Phillips #0 screwdriver.
4 участников успешно повторили данное руководство.
2 Комментариев
This doesn’t actually say anything about replacing the latch…
But where do you buy a replacement latch?
