Введение
The shutter switch is the button which is to be pressed when the user wants to capture an image. If for some reason this switch needs to be replaced, this guide will be showing how to remove the shutter switch.
Запчасти
No parts specified.
  1. Begin by opening the top of the camera (flash assembly) to a slight angle. Next, angle the flash assembly slightly upward and pry off the connections carefully. Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
    • Begin by opening the top of the camera (flash assembly) to a slight angle.
    • Next, angle the flash assembly slightly upward and pry off the connections carefully.
    • Be careful not to damage the ribbon cable. This is essential to the operation of the flash.
  2. Slide the action button, on the bottom of the camera, to open the bottom. Slide the action button, on the bottom of the camera, to open the bottom.
    • Slide the action button, on the bottom of the camera, to open the bottom.
  3. Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose. Pull off the face plate. Pull off the face plate.
    • Insert the blue plastic opening tool between the rear case and the plastic tabs directly under the shelf, and pry it loose.
    • Pull off the face plate.
  4. After the face plate is off, the shutter switch should slide out easily. After the face plate is off, the shutter switch should slide out easily. After the face plate is off, the shutter switch should slide out easily.
    • After the face plate is off, the shutter switch should slide out easily.
Заключение
2 участников успешно повторили данное руководство.
Tyler OBrien
Участник с: 22.09.2014
546 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 3-5, Brown Fall 2014 Member of USF Tampa, Team 3-5, Brown Fall 2014
USFT-BROWN-F14S3G5
3 членов
Автор 6 руководств
Один комментарий
where did you get the replacement parts for this?
Jacob Sokolove - Ответить
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
За всё время: 1,930
