Polaroid P902 LCD and Digitizer Replacement
Выберете то, что вам нужно
  1. Polaroid P902 LCD and Digitizer  Replacement, The Tools: шаг 1, изображение 1 из 3 Polaroid P902 LCD and Digitizer  Replacement, The Tools: шаг 1, изображение 2 из 3 Polaroid P902 LCD and Digitizer  Replacement, The Tools: шаг 1, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • The most important part of any repair is the tools used. Here's what I brought to this repair. Xool 58 in 1 Precision Screwdriver Set, DREMINOVA Heat soldering Mat Large Pad, and Xool 10pc EDS Anti-Static tweezers. I also always wear gloves when preforming repairs, my preferred gloves are Grease Monkey Disposable Nitrile Gloves.
  2. Polaroid P902 LCD and Digitizer  Replacement, The Back: шаг 2, изображение 1 из 3 Polaroid P902 LCD and Digitizer  Replacement, The Back: шаг 2, изображение 2 из 3 Polaroid P902 LCD and Digitizer  Replacement, The Back: шаг 2, изображение 3 из 3
    • First remove the two screws circled in the first picture with a PH00 bit.
    • After the screws have been removed take a plastic spudger and use it to lift the LCD from the backing
    • You will have to use some force don't be scared of it.
  3. Polaroid P902 LCD and Digitizer  Replacement, Ribbons: шаг 3, изображение 1 из 3 Polaroid P902 LCD and Digitizer  Replacement, Ribbons: шаг 3, изображение 2 из 3 Polaroid P902 LCD and Digitizer  Replacement, Ribbons: шаг 3, изображение 3 из 3
    • Next using the flat end of a plastic spudger release the clips holding the ribbon circled in the first picture.
  4. Polaroid P902 LCD and Digitizer  Replacement, The Screws: шаг 4, изображение 1 из 2 Polaroid P902 LCD and Digitizer  Replacement, The Screws: шаг 4, изображение 2 из 2
    • Next switching to a PH000bit remove the 4 screws circled in the first picture holding the motherboard down.
    • Now remove the four screw circled in the second picture along with their plastic components.
    • Be careful when removing the plastic part holding the speaker in so as not to rip the speaker wire
  5. Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: шаг 5, изображение 1 из 3 Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: шаг 5, изображение 2 из 3 Polaroid P902 LCD and Digitizer  Replacement, Removing the Digitizer: шаг 5, изображение 3 из 3
    • Flip the tablet over gently, then applying slight pressure on the left hand side lift the digitizer from the LCD
    • it should just lift right off. However you may need to do a bit of wiggling. Don't stress if it doesn't drop right off.
  6. Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: шаг 6, изображение 1 из 3 Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: шаг 6, изображение 2 из 3 Polaroid P902 LCD and Digitizer  Replacement, ALMOST THERE!!: шаг 6, изображение 3 из 3
    • Now go around the edges of the metal and release the metal tabs holding the LCD in place
    • I used an iSesamo to do this, made it super easy
    • On the left side of the LCD screen after removing the top metal plate you will see a strip of adhesive, remove it and your almost done
  7. Polaroid P902 LCD and Digitizer  Replacement, FINALLY!!: шаг 7, изображение 1 из 2 Polaroid P902 LCD and Digitizer  Replacement, FINALLY!!: шаг 7, изображение 2 из 2
    • Now lift the LCD straight up and out of the bottom casing and you're halfway through the repair :D
    • Now insert the new LCD and reverse the steps. Pat yourself on the back o grab some snacks and check out your like new tablet.
Заключение
Aj Jones
Участник с: 04/15/18
1 Репутация
1 руководство автора
Команда
Loading.. Game Repairs Участник Loading.. Game Repairs
Business
1 член
Автор 2 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 352
