Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Insert the flat end of a soft plastic opening tool between the screen and the back cover.
Pry the two pieces apart.
Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
Pry the battery up from the right side.
Remove the yellow plastic that covers the battery connector.
Use a soldering iron to remove the wires connected to the battery.
