Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If your screen is cracked or it is not responding to touch, follow this guide to replace the screen.
Запчасти
Детали не указаны.
  1. Insert the flat end of one of the plastic opening tools between the screen and the colored back cover. Gently pry apart the pieces. Carefully separate the screen from the back, taking care not to rip the ribbons connecting them.
    • Insert the flat end of one of the plastic opening tools between the screen and the colored back cover. Gently pry apart the pieces.
    • Carefully separate the screen from the back, taking care not to rip the ribbons connecting them.
  2. Insert the plastic opening tool into the wedge and pry it open. Insert the plastic opening tool into the wedge and pry it open.
    • Insert the plastic opening tool into the wedge and pry it open.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Open the latch and pull to remove the LCD.
    • Open the latch and pull to remove the LCD.
  5. After you remove the digitizer, open the latch and remove the screen.
    • After you remove the digitizer, open the latch and remove the screen.
  6. To install the new screen, insert the digitizer into the new screen and latch them back in.
    • To install the new screen, insert the digitizer into the new screen and latch them back in.
Заключение
Thiago Guedes
Участник с: 20.01.2015
17 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 1-2, Blackwell Winter 2015 Участник USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 65
