Введение
When replacing the battery, realize that there is an adhesive which binds the battery to the camera. Given the adhesive, force might be required to remove the battery. However, you should be able to remove it with your hands.
Выберете то, что вам нужно
Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
Screw head: Phillips, Screw length: 3mm
Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
Then it should be easy to simply lift the rear face plate up and remove it.
Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
Screw head: Philips, Screw length: 5mm
Once the screws are removed, flip the camera over
Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
Remove the battery by lifting up the battery from the left corner. If you can not remove the battery with your hands, consider using a Plastic Opening Tool
15 человек успешно провели ремонт по этому руководству.
24 Комментарии к руководству
I would like to know where to buy it too.
Same question need to know where to purchase a new battery and is this a common issue for the snap touch
I also need a battery and it seems almost impossible to find one to buy. Please let me know if anybody has found a replacement battery that fits.
