Введение
Replace a shutter button on the Polaroid SNAP.
Выберете то, что вам нужно
Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
Screw head: Phillips, Screw length: 3mm
Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
Then it should be easy to simply lift the rear face plate up and remove it.
Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
Screw head: Philips, Screw length: 5mm
Once the screws are removed, flip the camera over
Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
Look at the top left corner of the camera. This is where the shutter button is located.
Using the nylon spudger, locate the red tips under the shutter button.
Gently push on the shutter button tabs upwards, until the tab is dislodged. Repeat same steps for other two tabs.
Once shutter button has dislodged from underneath. Gently use your fingers to pull out the button, careful there is a spring underneath the button
2 участников успешно повторили данное руководство.
