Введение
This guide is intended for users who have Polaroid Z2300 with a malfunctioning control panel.
Выберете то, что вам нужно
Locate and remove the two 2.5 mm long screws on the bottom of the camera.
Screw head: JIS J00
Once the two screws are removed, flip the camera to back side up.
Use a plastic opening tool to disengage the outer plastic trim until it can be safely removed.
Use a plastic opening tool to pop the control panel off, it should be easy to lift up and remove.
