Введение
This guide will show you the required steps to complete a screen replacement.
Выберете то, что вам нужно
Locate and remove the two 3.5 mm long screws on the inside tray.
Screw head: JIS J00
Remove the inside tray.
Gently pull the ribbon away from the logic board. This will allow the screen to separate from the rest of the camera.
Locate and remove four 3.5 mm long screws on the inside of the door.
Screw head: JIS J00
Once the panel is removed, the malfunctioning screen will slide out and can be replaced.
