Polk MagniFi Soundbar Motherboard Replacement
Выберете то, что вам нужно
  1. Polk MagniFi Soundbar Motherboard Replacement, The Motherboard: шаг 1, изображение 1 из 1
    • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips'head in size J1.
    • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed.
    • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
  2. Polk MagniFi Soundbar Motherboard Replacement: шаг 2, изображение 1 из 2 Polk MagniFi Soundbar Motherboard Replacement: шаг 2, изображение 2 из 2
    • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
  3. Polk MagniFi Soundbar Motherboard Replacement: шаг 3, изображение 1 из 3 Polk MagniFi Soundbar Motherboard Replacement: шаг 3, изображение 2 из 3 Polk MagniFi Soundbar Motherboard Replacement: шаг 3, изображение 3 из 3
    • Remove the three sets of wires plugged into the motherboard (image 1). These are removed by gripping the base of the wire firmly and pulling straight up.
    • Unscrew and remove the four screws (two on either side) to release the motherboard from the rest of the soundbar (Images 2 & 3).
  4. Polk MagniFi Soundbar Motherboard Replacement: шаг 4, изображение 1 из 2 Polk MagniFi Soundbar Motherboard Replacement: шаг 4, изображение 2 из 2
    • Now that the soundbar is unscrewed, carefully lift the motherboard up and remove the wire attached to the underside of it. To do this firmly grasp the wires at the base (image 1) and pull them straight up.
    • The motherboard is now completely detached.
    • This component is fragile, and this step needs to be done carefully.
Заключение
2 участников успешно повторили данное руководство.
[deleted]
Участник с: 10/22/18
671 Репутация
Автор 4 руководств
11 Комментариев
Where do you buy the motherboard?
luism60613 - Ответить
Where do you buy the mother board?
klwalker1965 - Ответить
Where do you buy a replacement motherboard? ???
Todd Guenther - Ответить
Same question- where do you buy the replacement motherboard?
LL Poffo - Ответить
I need a motherboard - where do I purchase it?
Tim - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 8
За последние 7 дней: 31
За последние 30 дней: 83
За всё время: 7,372
