Введение
Taking off the back of this phone will allow you to look at or replace all of the pieces inside this device. This is a prerequisite guide for any other replacement you would like to accomplish with your SoundStation.
Выберете то, что вам нужно
Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
