Введение
Follow this guide to replace a dead or worn‑out battery in your FixHub Portable Power Station.
Выберете то, что вам нужно
Hold down the blue action button for five seconds to shut down your power station.
Collapse the kickstand.
Инструмент, используемый на этом этапе:FixMat$31.41
Use a T10 Torx screwdriver to remove the two 8 mm‑long screws securing the rear cover.
Grab the rear cover and pull the bottom edge towards you.
Remove the rear cover.
Insert the flat end of a spudger into one of the slots on either side of the battery connector. They're shaped just for this!
Use the spudger to begin prying up the connector.
Repeat the process and pry up on alternating sides of the battery connector to "walk" it off of the two plugs, enough that you can easily grip it with your fingers.
Grasp the battery connector by its edges and pull straight up to disconnect it.
Tuck the wires behind the connector, so the side of the connector with positive (+) and negative (-) markings is facing outward.
Align the connector over its two metal plugs so the negative (-) side is on the left of the USB‑C port and the positive (+) side is on the right.
Slide the connector onto its plugs and push down firmly until it's fully seated.
Place your fingers on the rear cover screw holes and push the chassis slightly out of the enclosure.
Slide the chassis fully out of the enclosure, making sure the battery connector doesn't get snagged.
Insert the battery connector side of the chassis into the end of the enclosure closest to the kickstand and slide it into place.
Use the flat end of a spudger or a clean fingernail to pry up the edge of the metal battery cover closest to the battery connector.
Remove the metal battery cover.
Hook the short edge of the cover without cutouts into place at the front, near the display.
Firmly press down on the opposite edge of the cover until it clips into place.
To reassemble your Portable Power Station, follow these instructions in reverse order.
Calibrate your newly installed battery after completing this guide.
4 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
I'm genuinely baffled iFixit doesn't have replacements for it's own product on stock. That made me take a huge step back while investigating the FixHub.
Adri, we're working to restock batteries. Feel free to use the Notify Me button to get updated when they're back in stock. We do have various other FixHub parts in stock: All Parts
