Введение
The power switch comes off of the router as a component attached to the black electrical casing around it. This guide will teach you how to remove that part.
Выберете то, что вам нужно
Use a Torx screwdriver to unscrew the 25.4 mm screws found at the top of the model.
Push the power switch through the top of the router. The power switch should now be completely detached from the router (besides the wire connections).
Find the wire plugs which are attached to the power switch. These connections are located at the back of the plastic box that houses the switch.
Use the spudger to carefully loosen the metal and rubber coverings, and detach the connections from the switch.
2 участников успешно повторили данное руководство.
