Введение
The motor brushes of the Porter-Cable PC60TAG provide a conducting path to the motor, and they may eventually wear down as the device begins to age. Use this guide to replace the brushes of your Porter-Cable PC60TAG.
Выберете то, что вам нужно
Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
Repeat steps 3-7 on the other side of the device.
Еще один человек закончил это руководство.
