Введение
Installing Modem involves removing the outer case and video card before installation.
Запчасти
Никакие детали не требуются.
  1. Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case. Push back the handle after you have taken the core out of the case. Push back the handle after you have taken the core out of the case.
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side. Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Slowly lift the plate off the cube and disconnect the power cord.
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Remove the four pillars from each corner.
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  6. Remove the screws on the back of the VGA port.
    • Remove the screws on the back of the VGA port.
  7. Remove the screw attaching the video card to the logic board.
    • Remove the screw attaching the video card to the logic board.
  8. Remove power cord from the video card. Remove power cord from the video card.
    • Remove power cord from the video card.
  9. Remove the power cord.
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
  10. Carefully lift the video card from the logic board.
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
  11. Separate the video card from the adapter. Separate the video card from the adapter.
    • Separate the video card from the adapter.
  12. Remove the two screws from the modem.
    • Remove the two screws from the modem.
  13. Lift modem from the Logic Board.
    • Lift modem from the Logic Board.
    • The modem should come out easily.
Заключение
Ryan Chun
Участник с: 24.06.2010
683 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 2-7, Johann Summer 2010 Member of Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 3
За всё время: 3,672
