Power Mac G4 M5183 Internal Battery Replacement
  1. Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: шаг 1, изображение 1 из 2 Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: шаг 1, изображение 2 из 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Fino a li lo intuisce anche un bambino. Io volevo sapere come levare l'altro sportello senza rompere niente. Ma una vodtra risposta non la vedo.
    giorgus - Ответить
  2. Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: шаг 2, изображение 1 из 2 Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: шаг 2, изображение 2 из 2
    • Locate the battery.
    • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
Финишная черта
21 участников успешно повторили данное руководство.
Justin Petrilli
Участник с: 01/21/10
3 114 Репутация
Автор 11 руководств
Команда
Cal Poly, Team 13-24, Maness Winter 2010 Участник Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 членов
Автор 25 руководств
4 Комментариев
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - Ответить
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - Ответить
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
Duard Kleyn - Ответить
The PMU reset button is inside the casing, on the same circuit board as the backup battery holder. See the second photo, it's a small silver square with a circular black button inset into its top and PMU Reset in tiny white lettering beside it. The photo shows it near to the battery holder but on my model the button is further away on the far corner of the circuit board. Look around for it. Insert the new battery then press the reset ONE time only.
Robert Nicholson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 25
За последние 30 дней: 135
За всё время: 25,295
