Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
The handle to open your computer is located on top of the right side panel.
Start by removing the screw holding the card to the chassis as shown.
Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
With the tab and screw removed, lift the card straight out.
First you want to remove the fan. Remove the two screws on the back of the computer in the upper left hand corner.
You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side.
Remove the four screws holding the CPU to the motherboard.
Now you can remove the CPU by pulling it straight up from the motherboard.
11 участников успешно повторили данное руководство.
