Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Removing the mother board of the Power Mac G4 Quicksilver.
Запчасти
Детали не указаны.
  1. The handle to open your computer is located on top of the right side panel.
    • The handle to open your computer is located on top of the right side panel.
  2. Grab the circular handle and pull outward. Grab the circular handle and pull outward.
    • Grab the circular handle and pull outward.
  3. Your computer is now open and ready for repair.
    • Your computer is now open and ready for repair.
  4. This is your Power Mac G4's video adapter.
    • This is your Power Mac G4's video adapter.
  5. Start by removing the screw holding the card to the chassis as shown.
    • Start by removing the screw holding the card to the chassis as shown.
  6. Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. With the tab and screw removed, lift the card straight out. When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  8. Disconnect both the power cables and IDE cable from the mother board.
    • Disconnect both the power cables and IDE cable from the mother board.
  9. Remove these three screws that hold the motherboard fan and modem connector to the chassis.
    • Remove these three screws that hold the motherboard fan and modem connector to the chassis.
  10. Remove the four screws shown to free the mother board from the chassis.
    • Remove the four screws shown to free the mother board from the chassis.
  11. Lift the fan shroud and fan straight up and out. Take care to disconnect the indicated connector Remove the heatsink clamps with a flathead screwdriver and do the same for the other side. Lift off the heatsink and remove the 4 screws of the CPU board.
    • Lift the fan shroud and fan straight up and out. Take care to disconnect the indicated connector
    • Remove the heatsink clamps with a flathead screwdriver and do the same for the other side.
    • Lift off the heatsink and remove the 4 screws of the CPU board.
    • There are 4 pins: remove the 3 pins near the RAM but not the pin nearest You.
    • You are now ready to slide gently (and without ANY difficult) the motherboard. Lift up and the game is done.
Заключение
9 участников успешно повторили данное руководство.
Cameron Christensen
Участник с: 20.01.2010
549 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 14-41, Regan Winter 2010 Участник Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 членов
Автор 17 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 34
За всё время: 15,175
