Введение
Removing the power supply of the Power Mac G4.
Инструменты
Запчасти
Детали не указаны.
The handle to open your computer is located on top of the right side panel.
The optical drive is in the top left corner of the case.
There are four screws to be removed.
The first screw can be seen in the first picture.
The remaining three screws can be seen in the second picture.
Remove the optical drive by pulling the drive away from the front of the computer and out.
Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
There is a total of four screws to be removed.
The first three can be seen in the first picture.
The final screw can be seen in the second picture.
There are three 2.5mm hex bolts located in the back of the computer that also need to be removed.
A 3/32" Hex Key or Hex Driver, or a T10 Torx, are a bit small but may also work if gentle.
Disconnect the power supply cables from the mother board by pressing in the tab on the back of the connector as shown.
Before sliding out the power supply make sure to disconnect the cable to the big fan by pressing in the small black tab on the back of the black connector!
Slide the power supply away from the back of the computer and pull it out carefully stringing the cables through the hole in the metal support.
19 участников успешно повторили данное руководство.
Комментариев: 5
I hate to say this, but that is not fixing the power supply but replacing the power supply with a new unit. i was hoping to fix it as mine blew and was hoping to revive it, but not luck on this end by the look of it. :(
Thanks for the clear instructions to replace the power supply. I got my part on eBay for $29 (other online stores are charging $100-200+ for it) to doctor up an old G4, and it works like a charm now.
Is it normal that after installing a replacement power supply for the PowerMac Quicksilver 733MHZ one of the fans is still running? Not sure which one, but once everything is shut down completely, I just pull the plug to avoid that fan from running for ever. Any feedback is appreciated. That unit still runs under OSX 10.4.11 and Classic.
