Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove all the cables, including the power cables before opening the unit.
Remove the air deflector (the clear plastic cover) by pulling on the handle.
Remove the battery by lifting the battery from the battery terminal.
The area should look like this after the battery is removed.
35 участников успешно повторили данное руководство.
7 Комментариев
plz advise the type of battery, thx !
Thank you, very very instructive - but why on Earth
does Apple not mark the battry holder on this model
with + and - ? ? Now, thanks to your close-up photo
I found out which way to turn the battery. (I hope)
Best regards
Torben, Denmark
Agreed - slot should be marked with + and – . . .
Thanks for the clear and sharp photos d;-)
Grazie, molto utile! Alberto da Venezia
