Power Macintosh G3 Blue and White PRAM Battery Replacement
Выберете то, что вам нужно
  1. Power Macintosh G3 Blue and White PRAM Battery Replacement, PRAM Battery: шаг 1, изображение 1 из 1
    • Unfortunately, I am unable to provide OG content for this step due to my Power Mac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White PRAM Battery Replacement: шаг 2, изображение 1 из 1
    • Locate the PRAM battery.
    • The PRAM battery is usually at the top right corner of the logic board.
  3. Power Macintosh G3 Blue and White PRAM Battery Replacement: шаг 3, изображение 1 из 1
    • Lift the battery out of the PRAM battery holder.
    • What I did to free the PRAM battery is I broke the plastic battery holder identical to the circled one on the other side of the PRAM battery, then I was able to free the PRAM battery. I couldn't get the PRAM battery to budge without breaking the holder.
    • Don't be worried, breaking the plastic holder won't cause much damage nor will it hinder the ability for the PRAM battery to stay in place. Only break one holder, though.
Заключение
2 участников успешно повторили данное руководство.
[deleted]
Участник с: 08/28/18
26 355 Репутация
Автор 21 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 8
За последние 30 дней: 40
За всё время: 2,398
